Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
Apr 14, 2022Guru - Experienced User
I see. OK. Well the message only appears once and doesn't seem to both anything. I'll leave the router at .v134 for now. I'll get this going live on a 2ndary network tomorrow and let it run over the weekend with WiFi enabled. WIll monitor.
mathmath51
Apr 15, 2022Apprentice
Hi, Does this version include fixes related to the DHCP issue please ?
No I'm not going to test it for the Netgear "QA" đ
- Netduma-FraserApr 15, 2022NetDuma PartnerThe change log does not mention it so it is very unlikely unfortunately
- FURRYe38Apr 15, 2022Guru - Experienced User
Currently running v.134 and not seeing any DHCP issue. I have left the DHCP server configuration at default.
