Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
Panos_78
Apr 17, 2022Guide
Hi FURRY,
If update the new firmware and after factory reset restore from backup I have any issues?
With .130 firmware after factory reset I don’t have it any problems. Need to update the new firmware? Is important? Router working better with .134?
Netduma-Fraser
Apr 17, 2022NetDuma Partner
Panos_78 it is not advised to upgrade, reset and then restore as you could bring issues back. It is more of a maintenance & security upgrade so it is recommended but depending on how you feel about that, not necessary. You're unlikely to have any performance improvements by upgrading.
