Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
connorcoolbeans
Apr 22, 2022Tutor
Hi everyone just updated to the newest firmware and as mentioned it is still very buggy and has the DHCP issue. Can everyone recommend from their experience what is the most stable version of previous firmware that is useable please?
Thanks in advance
- FURRYe38Apr 22, 2022Guru - Experienced User
Did you factory reset the router and setup from scratch? I'm not seeing the DHCP issue on my XR450 and i'm using default DHCP IP address range.
Thanks in advance
- connorcoolbeansApr 22, 2022Tutor
Yes factory reset via the pin hole for 30 seconds
- Netduma-FraserApr 22, 2022NetDuma PartnerOkay try the above regarding reserved IPs and see if that helps
- Netduma-FraserApr 22, 2022NetDuma PartnerAs above, also there is no specific fix for that issue in that version. If you haven't done so already the following can help with the disconnections. In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
