Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
Netduma-Fraser
Apr 23, 2022NetDuma Partner
You may just need to re-adjust your QoS settings but if you need to go back that's absolutely fine, nothing you need to do. Once our planned update goes out everything should be a lot more stable and bring it in line with other platforms.
satinghostrider
Apr 24, 2022Tutor
Is this a bug on the latest firmware 134 where under system information it still shows 130?
Anyone else can confirm?
Thanks!
- Netduma-LiamApr 25, 2022NetDuma Partner
Unfortunately I can't see the image as it's not been moderated yet.
Are you referring to the DumaOS version field? Perhaps try attaching the image rather than pasting it, I should be able to see it then.
- FURRYe38Apr 25, 2022Guru - Experienced User
Your picture shows v.134...
Thanks!
- Netduma-FraserApr 25, 2022NetDuma PartnerClear your browser cache/cookies and then it will update correctly
- satinghostriderApr 25, 2022Tutor
Actually, this issue occurs when using remote connection to the router but locally it seemed to reflect the correct version under system information. Oddly, I tried clearing the cache/cookie data this morning from my office before logging on to the router at home and it now shows the correct version.
Thank you for reconfirming. ***SOLVED***
- Netduma-LiamApr 26, 2022NetDuma Partner
That's great to hear, let us know if you have any other issues.
- Netduma-FraserMay 08, 2022NetDuma PartnerOf course not, that's something that will be fixed. I'll reply to your other comment in your topic.
- Netduma-FraserMay 15, 2022NetDuma PartnerI wouldn't suggest upgrading to a different OS, you may struggle to re-upgrade back to DumaOS and if you have any warranty left that would invalidate it.
- agent47isn1May 15, 2022GuideDude chill out it's not that serious there's stable firmware out there. If it affects your life so bad buy a different router.
- Retired_MemberMay 16, 2022And luckily the 134 update is not broken. The 130 update completely crapped itself after a while when I updated to that, I'm glad you guys fixed most of every bug in 134 on 130 most of everything wouldn't connect. After a while I updated I had to format it to factory default and now it all works
- agent47isn1May 16, 2022GuideI did this is a public forum plus I have the xr450 which is just like the xr500 minus small differences. Ive only had a few hiccups but for the majority of 2 years this router has been nothing short of amazing.
