Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
domino138
Jul 14, 2022Guide
Hi Liam - do you have any idea when the next version is coming out for the XR500 please?
Netduma-Fraser
Jul 14, 2022NetDuma Partner
domino138 we post any and all potential updates on the status of firmware here: http://support.netduma.com/en/support/solutions/articles/16000132677-dumaos-firmware-progress outside of that we don't have any extra information to give
- lenbo7777Jul 27, 2022Tutor
My XR500 had a problem - documented here:
...where it would sporadically restart and reset. Since upgrading to .134, I haven't experienced this again. But I also hadn't reserved any addresses. Earlier this week, I reserved one device and address in the LAN. My DHCP is set to 192.168.1.2 - 254.
The morning after I made the reservation, my router restarted and reset - just like it had previously.
Is anyone else experiencing this...and is there ever going to be any relief?
- FURRYe38Jul 27, 2022Guru - Experienced User
- Netduma-LiamJul 28, 2022NetDuma Partner
That is odd, I would suggest going through and reserving IP addresses outside the DHCP range, then see if you experience any further disconnections after that.
