Apr 12, 2022Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.2.134 Released
Enhancements: 04/12/2022
Remove Funjsq for PR SKU
Various security enhancements
Bug Fixes:
Fixes an issue where the name of an attached device cannot be changed in the device manager th...
- Jul 27, 2022
I recommend that you leave the DHCP IP address pool range set to a smaller range. You don't have to use the default range. I personally never use the factory range on any NG router. Also this provides room for static IP addressed devices as well. I use .100 to .150 as I only have around 30 devices. Plenty of room for additional devices if and when that happens.
We hope so, however don't have that info.
lenbo7777
Jul 27, 2022Tutor
My XR500 had a problem - documented here:
...where it would sporadically restart and reset. Since upgrading to .134, I haven't experienced this again. But I also hadn't reserved any addresses. Earlier this week, I reserved one device and address in the LAN. My DHCP is set to 192.168.1.2 - 254.
The morning after I made the reservation, my router restarted and reset - just like it had previously.
Is anyone else experiencing this...and is there ever going to be any relief?
Jul 27, 2022Guru - Experienced User
