Mar 20, 2025Guru - Experienced User
New - XR450/XR500 Firmware Version 2.3.3.136 Released
Security Fixes: 03/12/2025
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
XR450:
Download Link:...
Jun 02, 2025Guru - Experienced User
Did you load this version your XR450 to check to see actual FW version on the routers web page?
Gogle wrote:Hello. The firmware upgrade version in the downloaded ZIP file is incorrect. It is XR450 V2.3.2.134 -- NOT
XR450 V2.3.2.136 as it should be.
Gogle
Jun 03, 2025Aspirant
Both XR450 firmware V2.3.2.134 and
V2.3.2.136 are exactly the same size: 36.7 MB (38,529,153 bytes).
That likely would not be the case if they were different.
I got the v...136 zip file from the router's page on Netgear's website.
The router indicated it was v...134.
- FURRYe38Jun 03, 2025Guru - Experienced User
Thank you for confirming that. I've passed this on to NG. Hoping they can resolve it soon.
