Aug 16, 2019Guru - Experienced User
New - XR450/XR500 v2.3.2.56 Firmware Update Available...
New Features and Enhancements: Support France Free and Orange ISP of the IPTV configuration. Support GUI login weak password protection. Bug Fixes: Fixes security vulnerability issues. Fixes t...
- Aug 17, 2019
Replied back here:
Jl92 wrote:
I have posted my issue in the XR500 forum. This is just a note to mention that with the v56 FW, my internet access ceased on 8/16. I had auto update set on my router. Setup with 5268 AT&T modem was working great for past two months. Not sure if my issue is coincidence but it seems suspicious to come right when the new FW came out. Ive gone through all trouble shooting in manual, factory resets, reboots. Being helped by someone in the other forum but so far no luck.
jordi08110
Aug 16, 2019Tutor
After of received a New router by processing rma with us have The same problem with vlan tag affect to quos, i install this update but not solve this problem, i lose 2 weeks without router and when have the New returned by RMA, dont work the antibuffer quos upload... I very very sad by lose time without future with that.
Has a factory reset and setup from scratch been performed after the FW update?
What is "quos"? >QoS?
- jordi08110Aug 16, 2019TutorYes the qos dont work in upload with vlan tag, reset configuration before and after install update, think this update dont solve big problems... i test with various modems arcadyan livebox fibre (in mode bridge) and with Others ont (huawei hg8240h and similares, the problem not is the módem, is function of the xr500 never work with vlan tag... Lose time and money,
- FURRYe38Aug 16, 2019Guru - Experienced User
I would contact NG support again and let them know if your experiences with the recent FW update. If NG can't seem to fix this for you then, you might want to ask about a refund.
Good Luck.
jordi08110 wrote:
Yes the qos dont work in upload with vlan tag, reset configuration before and after install update, think this update dont solve big problems... i test with various modems arcadyan livebox fibre (in mode bridge) and with Others ont (huawei hg8240h and similares, the problem not is the módem, is function of the xr500 never work with vlan tag... Lose time and money,- jordi08110Aug 16, 2019Tutor
if right now I just contacted again as you already had an open case of the RMA, they have escalated the case to engineering that is already the upper level, the manager was not available so I will wait for the call within a few hours, I have little hope of being able to fix it since I'm not the only one with this problem, I don't know what to think it's supposed to be a software issue ... Even so, I expect at least the product reimbursement, since it does not work as it should and there are already many hours invested in trying to solve what a great loss of time and money for a simple router means for me thanks friend i waiting
