Aug 16, 2019Guru - Experienced User
New - XR450/XR500 v2.3.2.56 Firmware Update Available...
New Features and Enhancements: Support France Free and Orange ISP of the IPTV configuration. Support GUI login weak password protection. Bug Fixes: Fixes security vulnerability issues. Fixes t...
- Aug 17, 2019
Replied back here:
Jl92 wrote:
I have posted my issue in the XR500 forum. This is just a note to mention that with the v56 FW, my internet access ceased on 8/16. I had auto update set on my router. Setup with 5268 AT&T modem was working great for past two months. Not sure if my issue is coincidence but it seems suspicious to come right when the new FW came out. Ive gone through all trouble shooting in manual, factory resets, reboots. Being helped by someone in the other forum but so far no luck.
Aug 17, 2019Guru - Experienced User
Replied back here:
tfbit
Aug 20, 2019Tutor
A minor problem popped up after 4+ days of router uptime. My daughter child left the house with her phone about an hour ago but I just noticed it is still shown as online in Device Manager, both the tree view and the table view (even shows signal strength). This is using Chrome. Closed and reopened Chrome and it is still there. Tried IE and it also is still has an online status. Opened up the Nighthawk app on my phone and it is NOT shown to be online. Pretty happy so far with the new firmware. Another revision or two and it should be there. Thanks!
- tfbitAug 20, 2019Tutor
Update to the above post. Just went and looked at Device Manager again and watched it drop to "Offline". This was about an hour after the phone left the area.
