Aug 16, 2019Guru - Experienced User
New - XR450/XR500 v2.3.2.56 Firmware Update Available...
New Features and Enhancements: Support France Free and Orange ISP of the IPTV configuration. Support GUI login weak password protection. Bug Fixes: Fixes security vulnerability issues. Fixes t...
- Aug 17, 2019
Replied back here:
Jl92 wrote:
I have posted my issue in the XR500 forum. This is just a note to mention that with the v56 FW, my internet access ceased on 8/16. I had auto update set on my router. Setup with 5268 AT&T modem was working great for past two months. Not sure if my issue is coincidence but it seems suspicious to come right when the new FW came out. Ive gone through all trouble shooting in manual, factory resets, reboots. Being helped by someone in the other forum but so far no luck.
Aug 22, 2019Guru - Experienced User
I just setup my XR450 with v56 today on a 200/10 ISP and speed testing is to spec, via wired PC and NG Nighthawk app on iPhone 6sP and Android Galaxy Tab S2 pad.
QoS set for 70% on both sliders using "When High Priority Traffic is Detected."
Also have 2x EX7700 extenders connected. Smart Connect is enabled on the XR450.
I did find an issue, has to do with the NH app. Device Manager reports "Sorry, the action was failed. Please try again." when seleting this on iPhone. On Android pad reports "Connected devices not found." Both iphone and pad have up to date NH apps.
