Mar 01, 2022Guru - Experienced User
New - XR700 Firmware Version 1.0.1.48 Released
Security Fixes: 02/16/2022
Fixes security vulnerability issues.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
NOTE: This version of ...
BartXR700
Mar 01, 2022Guide
Thank you, we still waiting for new Beta 3.0. I hope you guys give it to us soon.
- xfalaxApr 03, 2022Tutor
It is incredible that with each update the netgear people do not fix the deactivation of Vlan ...... every time they update I lose internet because they deactivate the Vlan box.
Since the betas I've been reporting this problem and it's still the same.
Not to mention my XR700 which is gathering dust because it gave me more trouble than joy.- Netduma-FraserApr 03, 2022NetDuma PartnerVLAN is deactivated by default, if you just upgrade it should stay saved, only when you reset should it revert to being disabled. If you're having issues make a new topic and we'll be happy to help.
