Mar 01, 2022Guru - Experienced User
New - XR700 Firmware Version 1.0.1.48 Released
Security Fixes: 02/16/2022
Fixes security vulnerability issues.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
NOTE: This version of ...
onlywiseman
Jul 19, 2022Guide
Since the update to 1.0.1.48.
1) I have lost LAN connection to the printer.
2) Download speed is unstable typically 300s Mbps (I have gigabit service from Xfinity, 800s upto low 900s on good days).
3) Slower DumaOS interface with random crashes while configuring it.
Yes on factory reset (like 5 times).
Any new updates soon?
Netduma-Fraser
Jul 21, 2022NetDuma Partner
onlywiseman the only difference on this version is security fixes so I couldn't see how it would cause those issues at all if nothing else in your network changed. If you downgrade does it work as expected? We provide all updates on firmware progress here: http://support.netduma.com/en/support/solutions/articles/16000132677-dumaos-firmware-progress
