Mar 18, 2019Guru - Experienced User
New - XR700 v1.0.1.10 Firmware Available
New Features and Enhancements:
USB driver update to support Apple File System (APFS)
Login password enhancement
DHCP option 60 support for Internet configuration
Bug Fixes:
Improves s...
Shikwan68
Mar 19, 2019Star
The only problems I've noticed so far;
The router apps seem a bit more sluggish to load.
The Network Monitoring app hangs about 3-4 seconds after loading. It can no longer be monitored in real-time.
These both seem like memory resource issues.
- FURRYe38Mar 19, 2019Guru - Experienced User
What browser are you using? Does this happen in FF or Opera?
- Netduma-FraserMar 19, 2019NetDuma PartnerAlso did you do a factory reset after the upgrade?
