Mar 18, 2019Guru - Experienced User
New - XR700 v1.0.1.10 Firmware Available
New Features and Enhancements:
USB driver update to support Apple File System (APFS)
Login password enhancement
DHCP option 60 support for Internet configuration
Bug Fixes:
Improves s...
TOOMUCHSAUCE
Mar 19, 2019Apprentice
I also have the same problem. The entire UI is slow. Some panels will not load at all, such as the large panel on the lower left on the dashboard tab.
- Netduma-FraserMar 19, 2019NetDuma PartnerSame question and also clear the browser cache/cookies before hand and see if that improves it.
- Shikwan68Mar 19, 2019Star
I am using Microsoft Edge (convienent) but I did clear the cache last night before posting...however I'm watching the Network Snapshot and Network Overview pinned on my Dashboard and they seem to be running fine now so IDK. I didn't do a factory reset but if this issue persists I will and I'll keep you posted! Thanks for your response!
- FURRYe38Mar 20, 2019Guru - Experienced User
What browser are you using? Does this happen in FF or Opera?
Do a factory reset after the update and setup from scratch?
- Netduma_JackMar 20, 2019NetDuma Partner
Given you are using Edge I suggest you try Firefox or Chrome if you continue to have problems. Edge is compatible but it you run into weird issues like this it's wise going to another browser to see if that resolves the problem
- martyr444Mar 21, 2019Apprentice
This firmware does make the GUI much slower to open no matter what browser you use when you compare it to the previous version. I did all the factory resets. You can simply go back to the previous and immediately see a considerable difference on how much faster it opens.
