Mar 18, 2019Guru - Experienced User
New - XR700 v1.0.1.10 Firmware Available
New Features and Enhancements:
USB driver update to support Apple File System (APFS)
Login password enhancement
DHCP option 60 support for Internet configuration
Bug Fixes:
Improves s...
TOOMUCHSAUCE
Mar 19, 2019Apprentice
I also have the same problem. The entire UI is slow. Some panels will not load at all, such as the large panel on the lower left on the dashboard tab.
Netduma-Fraser
Mar 19, 2019NetDuma Partner
Same question and also clear the browser cache/cookies before hand and see if that improves it.
- Shikwan68Mar 19, 2019Star
I am using Microsoft Edge (convienent) but I did clear the cache last night before posting...however I'm watching the Network Snapshot and Network Overview pinned on my Dashboard and they seem to be running fine now so IDK. I didn't do a factory reset but if this issue persists I will and I'll keep you posted! Thanks for your response!
