Mar 18, 2019Guru - Experienced User
New - XR700 v1.0.1.10 Firmware Available
New Features and Enhancements:
USB driver update to support Apple File System (APFS)
Login password enhancement
DHCP option 60 support for Internet configuration
Bug Fixes:
Improves s...
manoloturbo
Jun 01, 2019Aspirant
When we going to get a update?
this is ridiculous i have to downgrade my router like almost month and half ago because the V1.0.1.10 have issues even is you turn your router off delete all your settings yesterday i have a update for the android app and still waiting for therouter update this is ridiculous we waste our money in arouter like this and 2 months waiting to fix a issue ???????????????
Netduma-Fraser
Jun 01, 2019NetDuma Partner
Unfortunately I can't speculate on when a firmware will be released but I'm sure they're hard at work. Issues like this can be quite tricky to pin down and so require extra resources/time to resolve.
- manoloturboJun 01, 2019Aspirant
Well if that the case the need to hire somebody that know how to fix this issue because almost 2 months really?
i know for fact that few people like me agree on this..
I should stay with my ASUS Router
Netduma-Fraser wrote:
Unfortunately I can't speculate on when a firmware will be released but I'm sure they're hard at work. Issues like this can be quite tricky to pin down and so require extra resources/time to resolve.- FURRYe38Jun 01, 2019Guru - Experienced User
Takes time and money to do FW updates. MFrs just don't make updates willy nilly. Can take up to 6-9months to release something depending upon current and new issues that have to be fixes, developed and tested before releasing.
You Right time and money well easy!!
STOP RELEASING NEW ROUTERS AND FIX THE ISSUES OF THE ONES YOU HAVE ALREADY ON THE MARKET
