Netduma_Jack
Sep 08, 2018NetDuma Partner
New Firmware for XR500: 2.3.2.32 (fixes disconnection issue)
 You can download here: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
 New features and enhancements:
 Improved the Smart Connect feature
 Supports USB printers.
 Supports...
Swc37
Feb 14, 2019Aspirant
So the firmware is older than the updated on and I am still having issues. I did not install the older firmware though since it was older. Any other suggestions why I keep getting kicked off and have to reboot my router every day?
Feb 14, 2019Guru - Experienced User
Did you install this version manually and continue to use the router or was a factory reset performed after installing this version and setup from scratch?
