crmontoy1
Feb 15, 2021Apprentice
New firmware V2.3.2.114 XR500
All the experiences and all the cases are unique!! For example mi settings with this router is weird ( it doesn’t mean that im not trust in netgear because i believe 100%) but i dont use geo filter, m...
Netduma-Fraser
Feb 20, 2021NetDuma Partner
Did you factory reset after the update as that is highly recommended!
paulja
Feb 21, 2021Tutor
No I didn't, I upgraded (as with previous version upgrades) by getting the recommendation through the router notification service, not this forum. I am reluctant to factory reset and lose everything on the 'off chance' it would sort the problem. It looks to me as though the firmware version between XR500 & EX7700 has drifted apart.
- Netduma-FraserFeb 21, 2021NetDuma PartnerOkay so that version just have security fixes, wouldn't make a difference to your issues at all. The beta version however could help, I would definitely suggest doing a reset after that though: https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
What are the custom settings you have that you don't want wiped?
