crmontoy1
Mar 21, 2021Apprentice
New Firmware v2.3.2.120 (XR500)
Hi!! I always trust in netgear and i came back to my XR500 i was using My Asus AC1900 so yesterday I decided install the new firmware .120 to make my review!! I’ve tried all the updates and all the po...
- Mar 24, 2021Yes just to extend the lease time so your IP doesn't renew too often. I'd suggest extending it to at last a week if possible.
Netduma-Liam
Mar 23, 2021NetDuma Partner
Did the connections come back up on their own or did you have to manually restart the router?
The issue with the servers on ping heatmap is something we can resolve with a cloud update hopefully, we won't need another firmware to fix that.
crmontoy1
Mar 24, 2021Apprentice
So to put u in context:
I did the upgrade after that i did the router reset then i applied my settings so everything was good i did the benchmark i check the results and i went to watch tv and i realized that all
The devices were without connection and i turned off the router later I turned on and everything was normal yesterday i sent my debug log... how i said in the morning im not at home i dont know if my router loses connection mean time im not there....
- Netduma-FraserMar 24, 2021NetDuma PartnerIf you sent it to Tim thank you, he'll take a look and use that to inform a fix.
What is the model of the modem/router the XR is connected to?- crmontoy1Mar 24, 2021ApprenticeMy router is XR500
- Netduma-FraserMar 24, 2021NetDuma PartnerI mean, what modem/router is the XR500 connected to, the device it is connected to that gives it internet
