crmontoy1
Mar 21, 2021Apprentice
New Firmware v2.3.2.120 (XR500)
Hi!! I always trust in netgear and i came back to my XR500 i was using My Asus AC1900 so yesterday I decided install the new firmware .120 to make my review!! I’ve tried all the updates and all the po...
- Mar 24, 2021Yes just to extend the lease time so your IP doesn't renew too often. I'd suggest extending it to at last a week if possible.
crmontoy1
Mar 24, 2021Apprentice
So to put u in context:
I did the upgrade after that i did the router reset then i applied my settings so everything was good i did the benchmark i check the results and i went to watch tv and i realized that all
The devices were without connection and i turned off the router later I turned on and everything was normal yesterday i sent my debug log... how i said in the morning im not at home i dont know if my router loses connection mean time im not there....
Netduma-Fraser
Mar 24, 2021NetDuma Partner
If you sent it to Tim thank you, he'll take a look and use that to inform a fix.
What is the model of the modem/router the XR is connected to?
- crmontoy1Mar 24, 2021ApprenticeMy router is XR500
- Netduma-FraserMar 24, 2021NetDuma PartnerI mean, what modem/router is the XR500 connected to, the device it is connected to that gives it internet
- crmontoy1Mar 24, 2021ApprenticeOhh my bad !!!
Spectrum modem cable
Hitron
Model: E31N2V1
