Kirill83Rus
Apr 24, 2018Aspirant
New firmware XR500
Tell me when will a new update for the router. What is expected in it from the new. What changes and corrections. Why not create a separate branch. In which will be indicated the terms and offers from...
Netduma-Fraser
Apr 24, 2018NetDuma Partner
I think it will be available within a few weeks. Everytime a new firmware is available it tells you on the Knowledge Base for that update what will be included. There will be some fixes and a few additional features for the Geo-Filter as far as I know.
MHussein
May 24, 2018Tutor
More VPN producers and probably custom VPN client will be included... That is a critical feature most people are waiting for. A few weeks is quite vague...
Is there a way to understand the roadmap and provisional dates?
- Netduma-FraserMay 24, 2018NetDuma PartnerYes new VPN solution is being tested currently. No not really, due to the fact that two development teams work on the router and bugs can cause setbacks.
- MHusseinMay 24, 2018TutorYour prompt response is much appreciated, hang in there and get us a robust firmware guys :)
Note that HMA is not the best solution, I have been testing across the big ones lately and ExpressVPN rules... I hope you are including it in the list or at least through custom config.- Netduma-FraserMay 24, 2018NetDuma PartnerCustom configs will be allowed so you can use whichever VPN provider you want!
