SleepyChicken
Oct 09, 2021Aspirant
New here and can't figure out Static IP
Hello All in the Netgear Community, I am new here and I just recently bought an XR1000 Pro Gaming Router (v. 1.0.0.58_1.0.44) and I am already having a lot of issues. 1. In the Start A New Di...
Netduma-Fraser
Oct 09, 2021NetDuma Partner
You can go to LAN Settings to set reserved IPs for devices. Can you expand on the Geo-Filter issue you're having? If you have the Geo-Filter enabled you'll likely need to add the chat servers to the allow list and you'll be good to go.
SleepyChicken
Thank you, Netduma-Fraser!
Found reservations under LAN settings. My fault for being blind LOL.
Let me get back to the whole geo-filter thing and educate myself a bit more so I can help better explain the situation I am facing.
Currently, I have it set to off and I'll play with it more later today.
As per my voice chat issues. Whether I am using Whats App, Discord, Signal or whatever to make my calls, I find myself constantly showing packets dropped for Audio. However when I switch back to my older router, I don't see this issue.
A little more about my set up:
ISP Modem/Router (Top Floor) ----> direct ethernet to basement port ----> connects to NetGear router.
Is there something I should know regarding this set up that may be affecting this packet loss in my voice calls?
Is there any configuration details I can provide from my DUMA OS that can help clarify my issue better to you, Fraser?
- Netduma-FraserOct 09, 2021NetDuma PartnerGotcha, I understand the issue, thanks for clarifying. Could be a few things, first in WAN Settings disable the protection options and set NAT to Open - does that help?
