Xboxlivegamer
Jun 07, 2018Aspirant
New ISP with XR500, Xbox Double NAT Strict.
Hi,
Today I changed ISPs and I have NAT Type: Strict, Double NAT Detected on my xbox one x, I have NAT filtering set to Open and Disable SIP ALG and Disable IGMP Proxying checked.
Any suggest...
Xboxlivegamer
I don't think I can access my ISP's hub, only my router. Should I call my ISP and ask them if can change that?
Netduma-Fraser
Jun 07, 2018NetDuma Partner
What's your physical setup exactly?
- XboxlivegamerJun 07, 2018Aspirant
It's Wireless High-Speed Internet, a cable runs from outside to an PoE Adaptor, the LAN cord from that goes straight into my XR500 router and a ethernet wire from port 1 goes into my xbox.
