Xboxlivegamer
Jun 07, 2018Aspirant
New ISP with XR500, Xbox Double NAT Strict.
Hi,
Today I changed ISPs and I have NAT Type: Strict, Double NAT Detected on my xbox one x, I have NAT filtering set to Open and Disable SIP ALG and Disable IGMP Proxying checked.
Any suggest...
Netduma-Fraser
Jun 07, 2018NetDuma Partner
Put the console in the DMZ of the XR500 and remove any port forwards you may have done for it. If you don't get an open NAT in console network settings then may be some weird restrictions on ISP side as shouldn't have a double NAT with that setup.
Xboxlivegamer
I reserved an IP address for my xbox and entered that into Default DMZ Server, nothing changed.
Any more suggestions? Should I talk to my ISP and ask them if the hub is set to router and not modem mode?
- Netduma-FraserJun 07, 2018NetDuma PartnerIt doesn't sound like you have a hub but yes Id suggest that and we can go from there
