Xboxlivegamer
Jun 07, 2018Aspirant
New ISP with XR500, Xbox Double NAT Strict.
Hi,
Today I changed ISPs and I have NAT Type: Strict, Double NAT Detected on my xbox one x, I have NAT filtering set to Open and Disable SIP ALG and Disable IGMP Proxying checked.
Any suggest...
Jun 07, 2018Guru - Experienced User
What version of FW are you using on the XR500?
Press the Power button on the xbox until it shuts off. This will clear out any networking caches. Then power ON and check NAT status.
If you only have one xbox then set NAT FIlter to secure. Open is only needed for two or more game consoles.
Xboxlivegamer wrote:
Hi,
Any suggestions on what I can do to change this?
- XRaptor29Jun 07, 2018LuminaryI have two Xbox ones with open Nat and Nat is set to secure. From what my understanding is if you play CoD then you have to have Nat set to open. It's the only game that needs it.
- XboxlivegamerJun 07, 2018Aspirant
Firmware Version 2.2.1.10
I've noticed when I first log into my router it says Script Error and also when I use firmware update assistant it says my current GUI language version is V1.0.0325 and the new one is 1.0.0.327, I tried updating it but it doesn't change to the new version.
Power cycling my Xbox One X and restarting my router was what I tried first, I have 2 Xbox Ones wire connected to my router.
I called my ISP and the tech said the company was moving servers around so he couldn't edit any settings til tomorrow, so if nothing changes around then I should call back. What he was going to try, he said works 99% of the time so I'll have more information to relay tomorrow.
Thanks for the assistance from everyone.
- Netduma-FraserJun 08, 2018NetDuma PartnerWhat page do you see script error on?
For the language change language then change back to English and that will update it.
Okay let us know what they say, sounds positive! - FURRYe38Jun 08, 2018Guru - Experienced User
At some point, try setting NAT Filter to OPEN and reboot the router, Power OFF both xboxes then power back on the 1st box after the router reboots. Check NAT. Then power ON the 2nd xbox, Check NAT.
- wub901Jun 10, 2018Guide
as th
I fixed my the nat issue with the xbox by putting all the xbox ports into port triggering and left the specific i[ blank so it covers both the xbox,s
you may have to add some ports twice as they cover both UDP and TCP.
These ports must be open for Xbox Live to work:- Port 88 (UDP)
- Port 3074 (UDP and TCP)
- Port 53 (UDP and TCP)
- Port 80 (TCP)
- Port 500 (UDP)
- Port 3544 (UDP)
- Port 4500 (UDP)
