Xboxlivegamer
Jun 07, 2018Aspirant
New ISP with XR500, Xbox Double NAT Strict.
Hi,
Today I changed ISPs and I have NAT Type: Strict, Double NAT Detected on my xbox one x, I have NAT filtering set to Open and Disable SIP ALG and Disable IGMP Proxying checked.
Any suggest...
Xboxlivegamer
Firmware Version 2.2.1.10
I've noticed when I first log into my router it says Script Error and also when I use firmware update assistant it says my current GUI language version is V1.0.0325 and the new one is 1.0.0.327, I tried updating it but it doesn't change to the new version.
Power cycling my Xbox One X and restarting my router was what I tried first, I have 2 Xbox Ones wire connected to my router.
I called my ISP and the tech said the company was moving servers around so he couldn't edit any settings til tomorrow, so if nothing changes around then I should call back. What he was going to try, he said works 99% of the time so I'll have more information to relay tomorrow.
Thanks for the assistance from everyone.
Netduma-Fraser
Jun 08, 2018NetDuma Partner
What page do you see script error on?
For the language change language then change back to English and that will update it.
Okay let us know what they say, sounds positive!
