Xboxlivegamer
Jun 07, 2018Aspirant
New ISP with XR500, Xbox Double NAT Strict.
Hi,
Today I changed ISPs and I have NAT Type: Strict, Double NAT Detected on my xbox one x, I have NAT filtering set to Open and Disable SIP ALG and Disable IGMP Proxying checked.
Any suggest...
wub901
Jun 10, 2018Guide
This is my port triggering setup not sure if I set it up correctly but I get open ports on both the xbox,s the ps4 i put in the DMZ
MY SETUP
Xboxlivegamer
Aug 13, 2018Aspirant
Sorry for taking a long time to reply.
I no longer have double NAT, however it says "UPnP is not successful" on my xbox one x, UPnP is set to on in my router's settings.
My NAT is Moderate.
I also tried your port triggering settings and there was no change.
