jdklein
Jan 17, 2020Tutor
New patch, no broadcast
Applied the latest patch and now getting no SSID broadcast. Multiple reboots. Pushed wifi on off button, has no effect. Anyone else with this problem?
Netduma-Fraser
Jan 21, 2020NetDuma Partner
Check within Settings > Advanced > Advanced WiFi Settings that the radios are turned on, if they are then disable it, apply, then reboot the router. Then enable them, apply and reboot the router, does it come back then?
Also check SSID broadcast in the normal WiFi settings to ensure that's enabled for 2.4/5GHz.
