Nopatients4this
Mar 31, 2020Aspirant
New purchase can’t connect with existing cable
I just bought this router to try and improve my overall Internet experience and the old AT&T router has a phone cable going into it this new router only accepts ethernet can I just simply use a patch ...
Nopatients4this
Apr 01, 2020Aspirant
How should I connect it to the AT&T modem, do I use an ethernet port from AT&T to the internet port on the net gear? and how do I put the AT&T modem into that mode?
Netduma-Fraser
Apr 01, 2020NetDuma Partner
Use an ethernet cable to connect the LAN port of the AT&T to the Internet port of the XR500. You would need to access the AT&T router and adjust the settings there. Usually there will be a sticker on the router to tell you how to access the interface. If not look up your AT&T model online and it should show you how.
