Wxyz1234
Mar 24, 2020Aspirant
New router / Modem
I was thinking about buy Xr300 but I had a few questions . I’m not too tech savvy about things. If I buy this router do I need a modem for it to work . And if I do need a modem , Is there any way I ca...
Mar 24, 2020Guru - Experienced User
most routers need some type of gateway. Maybe its a modem, maybe its an ont from their provider. We can't tell you what you'd need exactly. Whoever is your isp will need to discuss with you what type of gateway you need and how to activate it.
Wxyz1234
If it is a modem I need , do I need a computer to set up a modem ?
- plemansMar 24, 2020Guru - Experienced User
Again, contact your isp.
some isp's will activate it when they install, some do self activation, some don't require modems, some you can activate the modem over the phone, or some make you use a modem/router combo. You'll first need to call your isp to figure out what they need.
- Netduma-FraserMar 24, 2020NetDuma PartnerIf you do not have internet at all already then it will be dependent on the ISP you go with/what model of modem/router they give you. In regards to the XR300 you will need an existing internet connection with either an ONT/modem/router to connect the XR300 to. You can then connect to the XR300 via WiFi with your PC to set it up.
