Gimli
Jun 04, 2018Tutor
New update V2.3.2.18
Hello, I saw that a new update came out V2.3.2.18, is it safe to update or is there a problem after the update?
Thank you
Netduma-Fraser
Jun 05, 2018NetDuma Partner
Hi Gimli, if you upgrade and do a factory reset to clear out any legacy issues that could be caused by old firmware then you shouldn't have a problem. Some are seeing UPnP table blank which we're looking into, doesn't necessarily mean it will affect NAT status.
- Fibtls18Jun 06, 2018Guide
my table is blank and ps4 is constant moderate or strict Nat types now even after manually opening up 3074? Everything was great before the update now its just went to **bleep** any insight?
- Netduma-FraserJun 06, 2018NetDuma PartnerSuggest putting console in DMZ or downgrading to the previous version while this version is investigated
does this work on a wired connection?
