Gimli
Jun 04, 2018Tutor
New update V2.3.2.18
Hello, I saw that a new update came out V2.3.2.18, is it safe to update or is there a problem after the update?
Thank you
Netduma-Fraser
Jun 05, 2018NetDuma Partner
Hi Gimli, if you upgrade and do a factory reset to clear out any legacy issues that could be caused by old firmware then you shouldn't have a problem. Some are seeing UPnP table blank which we're looking into, doesn't necessarily mean it will affect NAT status.
Fibtls18
Jun 06, 2018Guide
my table is blank and ps4 is constant moderate or strict Nat types now even after manually opening up 3074? Everything was great before the update now its just went to **bleep** any insight?
- Netduma-FraserJun 06, 2018NetDuma PartnerSuggest putting console in DMZ or downgrading to the previous version while this version is investigated
- Fibtls18Jun 06, 2018Guide
does this work on a wired connection?
- Netduma-FraserJun 06, 2018NetDuma Partner| Stylz - It has not caused any major issues i.e. causing your internet to go down. If you have UPnP issues then downgrade until it's fixed.
| Fib - Not sure I quite get what you're referring to, DMZ? If so yes. - StylzJun 06, 2018Tutor
You will get a connection BUT you will lose all GeoFilter features (some are able to still use but get a blank upnp table. I'D RECOMMEND NOT UPDATING and RETURNING THE XR500 if you can. It is full of bugs and ZERO solutions besides resetting and trying again. Not sure what NetGear was thinking when releasing this POS. Good luck
