Gimli
Jun 04, 2018Tutor
New update V2.3.2.18
Hello, I saw that a new update came out V2.3.2.18, is it safe to update or is there a problem after the update?
Thank you
Stylz
Jun 06, 2018Tutor
Cannot use GeoFilter, QOS errors, blank tables, WiFi is AWFUL, sick and tired of resetting only for it to still suck. DMZ this, QOS that...this has to be the biggest waste of my hard earned money. Should come with a warning label..."Be prepared to constantly reset prior to updating firmware". Netgear/Duma FAIL FOR SURE!
Netduma-Fraser
Jun 06, 2018NetDuma Partner
This is the only firmware where a reset has been needed for some in order to solve an issue. It is annoying thats why it was pulled to be fixed.
If you've been having issues previously then i'd recommend calling Netgears 24/7 support line.
- GimliJun 06, 2018Tutor
Will we have a new firmware to fix the problems?
- KillhippieJun 07, 2018Prodigy
Netgear will release new firmware when they have sorted the issues out.
- Netduma-FraserJun 07, 2018NetDuma PartnerYes I believe they are working on a fix now and are rethinking the rollout process.
Killhippie/Case850, if you're going to bicker with each other I'd suggest doing it elsewhere, not in a support post. - Fibtls18Jul 04, 2018GuideUpdate to the 2.3.2.22 or stay on the 18?
- Netduma-FraserJul 04, 2018NetDuma PartnerUpdate :)
