Gimli
Jun 04, 2018Tutor
New update V2.3.2.18
Hello, I saw that a new update came out V2.3.2.18, is it safe to update or is there a problem after the update?
Thank you
Gimli
Jun 06, 2018Tutor
Will we have a new firmware to fix the problems?
Netduma-Fraser
Jun 07, 2018NetDuma Partner
Yes I believe they are working on a fix now and are rethinking the rollout process.
Killhippie/Case850, if you're going to bicker with each other I'd suggest doing it elsewhere, not in a support post.
