DCW3
Oct 28, 2021Follower
New XR1000 Slow Wifi
I replaced my XR500 with a new XR1000. Same location, same cables. Speedtest in the Nighthawk app shows it is running 218.71M down, and 11.36 up. However, none of my devices are receiving better t...
Netduma-Fraser
Oct 28, 2021NetDuma Partner
Disable Smart Connect on the XR and then manually connect to 5GHz, what speeds do you get then?
