d0x
Jan 20, 2022Guide
New XR1000, upnp disabled, nat issues, other errors
I just bought an XR1000 yesterday and I was setting it up and after I was done and the firmware was updated I started getting some errors and I was also unable to enable upnp which was disabled by def...
d0x
Jan 20, 2022Guide
Armor is disabled, last night it was Chrome on Win10 and right now I'm looking at stuff on Edge for android 12. upnp is definitely not enabled or at least not behaving like it is, I can take my Ethernet cable and plug it into my TP-Link ax6000 and Nat is open. Then do the same with this and it's moderate.
While looking through the forums and help files I noticed that the upnp issue has existed for like 6+ months... Which is concerning. One would think that would be an easy fix but there hasn't been a FW update in quite some time which is also concerning
Also why isn't there a 6ghz wifi band? Did I miss a setting somewhere? I set it up last night around 3am and I'm just getting going now so I'll get you more info within the hour, I just need to let the caffeine touch my heart lol.
Seriously though... Why isn't the router listed in the product selection but the xr500&700 are? I find that a little concerning. Concerning enough that I'm thinking I should have bought the ROG whatever it's called (see, caffeine!) Wifi6e router.
Thanks for the quick response as well. I appreciate it.
Netduma-Fraser
Jan 20, 2022NetDuma Partner
It will be working but it depends on how your network is setup as to whether you'll get an Open NAT right away, if you're also using the Geo-Filter it may produce a false NAT result. If you could provide the errors when you can that would be really helpful.
It doesn't have 6GHz WiFi, that is for WiFi 6E and the XR1000 is WiFi 6. It's a community forum so Netgear won't be monitoring the forums too much so just hasn't been added yet.
- d0xJan 20, 2022GuideYep, 6e, air traffic controllers and unlicensed spectrum for now.. sorry I'm running on 4 hours of sleep in the last 2.5 days.
So now the error messages aren't popping up but essentially they were small popup windows themed like duma, not a win32 style error msg and they had what looked like a couple random letters and numbers all the way on the right side. If one shows up I'll get a screenshot.
So NAT was moderate despite QOS being off and the devices and router had been running for roughly 8 hours. Basically everything is at default out of box setting except for the basics.
I specifically bought this because of Duma but now I'm regretting not just buying the ROG AXE-11000 but only because I'm getting frustrated.- Netduma-FraserJan 20, 2022NetDuma PartnerOkay keep us posted on the errors. What is the model of the modem/router the XR is connected to? Once you start using the features I'm sure you'll be happier!
Netduma-Fraser ok these arent the errors i was seeing at 4am but the first came up right after logging in and the 2nd came up when i clicked system information. Im still trying to trigger the ones i was seeing before but it could have been a fluke, with that said they were appearing on most pages
Right after loginafter clicking sys info
