d0x
Jan 20, 2022Guide
New XR1000, upnp disabled, nat issues, other errors
I just bought an XR1000 yesterday and I was setting it up and after I was done and the firmware was updated I started getting some errors and I was also unable to enable upnp which was disabled by def...
Netduma-Fraser
Jan 20, 2022NetDuma Partner
It will be working but it depends on how your network is setup as to whether you'll get an Open NAT right away, if you're also using the Geo-Filter it may produce a false NAT result. If you could provide the errors when you can that would be really helpful.
It doesn't have 6GHz WiFi, that is for WiFi 6E and the XR1000 is WiFi 6. It's a community forum so Netgear won't be monitoring the forums too much so just hasn't been added yet.
d0x
Jan 20, 2022Guide
Yep, 6e, air traffic controllers and unlicensed spectrum for now.. sorry I'm running on 4 hours of sleep in the last 2.5 days.
So now the error messages aren't popping up but essentially they were small popup windows themed like duma, not a win32 style error msg and they had what looked like a couple random letters and numbers all the way on the right side. If one shows up I'll get a screenshot.
So NAT was moderate despite QOS being off and the devices and router had been running for roughly 8 hours. Basically everything is at default out of box setting except for the basics.
I specifically bought this because of Duma but now I'm regretting not just buying the ROG AXE-11000 but only because I'm getting frustrated.
- Netduma-FraserJan 20, 2022NetDuma PartnerOkay keep us posted on the errors. What is the model of the modem/router the XR is connected to? Once you start using the features I'm sure you'll be happier!
