erfont
Apr 07, 2021Aspirant
new XR500 chromecast built in set up
I just upgraded to a XR500 from a 6300V2 and I can not get chromcast built-in set up on either of my Nvidia shield TVs. It worked without any issue yesterday with the 6300v2. I'vebeen trying every po...
erfont
things i've tried:
-turned off smart connect and set up all device on the same 5g wifi
-checked and updated firmware on all devices: phone, both shields, router
-deleted stored wifi networks. reconnect and save only the 5g. all device show connected to it in DUMAOS
-deleted all devices from Google Home.
-factory reset one of the shields
-toggled UPnP
-toggled IPv6
Everything was working fine yesterday with the R6300V2. The XR500 is the variable
Netduma-Fraser
Apr 08, 2021NetDuma Partner
Could you try using the 2.4GHz network instead of 5GHz please? I realize you'll want to use 5GHz for high bandwidth so just for trouble shooting purposes.
