OminousTree's avatar
OminousTree
Initiate
Jan 01, 2019
new XR500 router blocks android apps from opening
So iv updated the firmware upon setting up the router and have tried changing nearly all the settings i thought could be the issue (hybrid vpn, geofiltering, qos, duma os classified games, etc...) bu...
  • FURRYe38's avatar
    Jan 01, 2019
    What FW is currently loaded?
    What WPA security modes are you using? Try WPA2 and AES only.
    IPv6
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
