chunk1982
Aug 04, 2018Tutor
new xr500 user
i recently got my xr500 and was wondering if anyone can give me an easy to follow but full instructions on how to configure it with my xbox one x please as to be honest im a little blagged lol
so f...
- Aug 04, 2018Hi Paul - it sounds like your settings are really good to be honest. If you have an open NAT there’s no reason to apply any port forwarding rules. UPNP will automatically do this for you (and it’s enabled by default)
I would recommend putting your geo-filter into filtering mode if you want to force a nearby server in your favourite games.
Here are some optimal settings guides for you though if you’re interested in learning more:
http://support.netduma.com/support/solutions/folders/16000090646
Netduma_Jack
Aug 04, 2018NetDuma Partner
chunk1982
Aug 04, 2018Tutor
Hi jack thank you for taking the time to reply to my message, it's very much appreciated and also for the link and additional information I will definitely be having a read and another play 👌👌
Many thanks and all the best
Paul
Paul
