shunk
Aug 27, 2022Tutor
Next firmwar xr 500
I would just like to know when the new firmware for the xr 500 will be released and if there will be a resolution of the dhcp bug and if there will be ping assist functionality
shunk
Aug 27, 2022Tutor
Oh sorry I meant the auto setup of the congestion control for optimise my fiber connection not ping assist sorry
what would you recommend for the congestion control for a 950/800 connection
Netduma-Fraser
Aug 27, 2022NetDuma Partner
Ah yes that will be in the next version I believe. We always recommend 70% as a starting point for both download/upload and then if you continue to have local congestion then experiment with the values until you find what works best for you.
