KadeW
Jun 18, 2022Aspirant
NEXTDNS ADBlock Setup on XR1000
Hello, I'm trying to setup NEXTDNS on Dumaos the steps given are - IPv4 (with Linked IP) 1. Open the preferences for your router. Usually you can access it from your browser via a URL (like htt...
michaelkenward
Jun 19, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
