KadeW
Jun 18, 2022Aspirant
NEXTDNS ADBlock Setup on XR1000
Hello, I'm trying to setup NEXTDNS on Dumaos the steps given are - IPv4 (with Linked IP) 1. Open the preferences for your router. Usually you can access it from your browser via a URL (like htt...
Netduma-Fraser
Jun 19, 2022NetDuma Partner
You can find that on the Internet Setup page - it's the page that opens when you first click on Settings in the menu, just scroll all the way down on Internet Setup and you'll find it.
KadeW
Jun 19, 2022Aspirant
Is this the correct location I posted?
- michaelkenwardJun 20, 2022Guru - Experienced User
Looks like it.
Use These DNS Servers
Read about it in the manual for the XR1000.
- Netduma-FraserJun 20, 2022NetDuma PartnerYes you've got it, as above select Use These DNS servers and then you can put in the DNS you need
