grdmstr75
Sep 04, 2020Aspirant
NG NH xr500 - first time router rebooted on its own.
today router rebooted first time ever since i have had it almost two years., any way to debug why it did this. from bash terminal? really do not want to replace it right now expensive to update....
grdmstr75
Sep 05, 2020Aspirant
Hi, i did not mean that it has not been rebooted in 2 years it has been rebooted many times especially these days due to quarintine BS, anyways what i meant was it has never rebooted on its own in the middle of the day like that.. there was a lot of traffic during this time yes but to reboot like that just strange. is there any way i can debug it by logging into the command line of it? i just want be able to do this anyways to check configs , should i update to the latest firmware?
Netduma-Fraser
Sep 05, 2020NetDuma Partner
Understood, I would recommend reinstalling the firmware you are on using the TFTP method to bypass any issues in the boot process, then do a factory reset. That will give you the freshest install possible and hopefully prevent any unexpected reboots. https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- grdmstr75Sep 05, 2020Aspirant
please let me know is there a command line interface for the router? it is based off linux no?
- Netduma-FraserSep 05, 2020NetDuma Partner
There is Telnet but it won't help you as any logs would be wiped upon a reboot.
ok how about going forward so i use SFCP to login? what app like putty?
