Night__XR500
Mar 11, 2023Tutor
Ngithhack XR500 NAT Loopback setup?
 Hi All,     I have a Nighthawk XR500 running a home server with email.  It is pretty annoying that I cannot access services using the WAN IP address - e.g. webmail and IMAP.     As far as I can detec...
- Apr 22, 2023
Hi all,
I finally gave up. Changed broadband provider and got a Zyxel router. Whatever the cause, it solved the problem without changing anything in my network setup.
Best regards
Netduma-Fraser
Mar 11, 2023NetDuma Partner
This would be a Netgear feature but I'll do my best to help - are you using the WAN IP shown on the System Information page i.e. the IP assigned to the XR500 from the modem it's connected to or the public IP? There is also a remote management option you can enable in settings, enable that and see if it works
Night__XR500
Mar 12, 2023Tutor
Naturally I am using the WAN IP. Not sure what external IP you would alternatively consider?
No. The remote management is not activated - for security reasons. What difference should that make?
- Netduma-FraserMar 12, 2023NetDuma PartnerThe only two IPs you could try would be the IP assigned to the XR or your public IP so I was just checking. As that option allows you to access the interface from the WAN side and is the only option on the router that relates to accessing from the WAN it may help the functionality you want to work - whether it should or not is another matter but we're troubleshooting so it's worth a try, even if you disable it afterwards. What is the modem/router the XR is connected to?
- Night__XR500Mar 13, 2023Tutor
Hmm .. I think we are talking about different issues.
The problem is that I cannot access the webservices running on my own server on the intranet with the same URL as externals can - the router seems to be unable to serve an open net (external IP) call to my own server (within the 192.168.x.x) if it comes from the intranet (within the 192.168.x.x address space) the same way as if the call originate on the open net.
If I take the exact same laptop and connect to the net from outside the intranet (e.g. through a mobile phone wifi hotspot instead of the wifi the service is connected to), I get a different result. Then it works fine.
I cannot find anything on the nat loopback settings
- Netduma-FraserMar 13, 2023NetDuma PartnerThe only thing I can think of that would possible help in this situation would be to look at the WAN Settings on the router, e.g. set NAT to Open/disabling the protection options there. Other than that there aren't any more settings for NAT or NAT loopback
