Night__XR500
Mar 11, 2023Tutor
Ngithhack XR500 NAT Loopback setup?
 Hi All,     I have a Nighthawk XR500 running a home server with email.  It is pretty annoying that I cannot access services using the WAN IP address - e.g. webmail and IMAP.     As far as I can detec...
- Apr 22, 2023
Hi all,
I finally gave up. Changed broadband provider and got a Zyxel router. Whatever the cause, it solved the problem without changing anything in my network setup.
Best regards
Night__XR500
Apr 22, 2023Tutor
Hi all,
Best regards
Netduma-Fraser
Apr 22, 2023NetDuma Partner
Thanks for the update, glad you were able to get it all sorted out
- FURRYe38May 03, 2023Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
