Tybn
Nov 06, 2020Tutor
Night hawk x500 connection to NBN
Hello. I have recently moved into a new property and have had satellite NBN installed. The tech was on site today and indicated that the NBN is installed and receiving data. I connected my X500 to th...
- Nov 09, 2020Problem solved.
I changed the bridge control Settings in the router and it has worked a treat.
All up and running now.
Netduma-Fraser
Nov 07, 2020NetDuma Partner
For some PPPoE connections they also require a service name otherwise they won't connect, could you contact the ISP and ask them what specific details are needed to gain a connection please?
Tybn
Nov 09, 2020Tutor
Problem solved.
