MK3msa
Mar 05, 2019Initiate
Night Hawk XR 500 getting [DoS Attack: IP Spoofing] from source: 192.168.1.22
Noticed earlier todat that my donload speed has significantly decreased. Checked router info and noticed that I am seeing [DoS Attack: IP Spoofing] from source: 192.168.1.22, Tuesday, March 05, 201...
Netduma_Jack
Mar 06, 2019NetDuma Partner
Hi there - that's unlikely to be related (https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/DoS-Attack-IP-Spoofing-from-source-192-168-1-1-port-57985-Monday/m-p/1716507#M8772)
It's more likely that either your Internet speeds have dropped from your provider, or there's a setting on the router.
To figure out if it's the first one, try connecting directly to your modem and running a speedtest. What are your speeds? Then connect the same device back to your XR500, are the speeds the same or lower?
If they're lower, please follow this guide to make sure none of your settings are slowing down the router: http://support.netduma.com/en/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-maxmimum-bandwidth-speeds
- MK3msaMar 06, 2019Initiate
Thank you for the insight. I'll try your suggestions tonight and let you know what turns up. Thanks again for the quick response.
