Beef311
Apr 08, 2020Initiate
Night hawk xr 500 internet connection
Need help getting back on internert
Apr 08, 2020Guru - Experienced User
And we need help to help you.
1. what modem are you connected to?
2. firmware on the router?
3. what happened? you put you need help getting back online. are all devices down, just wired device, did the power die, what exactly happened, what have you done to try to fix it, and details of whats going on with the modem and router help us to help you.
- Beef311Apr 08, 2020InitiateI finally got it reconnected I run a 32 channel cable modem netgear with the night hawk xr 500
