ajkron
Dec 14, 2018Guide
night hawk xr500 slow speeds all of the sudden
wireless speeds were great then all of the sudden they went down to 30-40. was getting 300 plus. when i connect to my modem i can achieve 300plus. i am on uverse gig service. i have tried all the...
- Dec 15, 2018You should get 3 months support with them I think.
A possible trick is to give the XR500 the MAC address of your previous router. Sometimes the ISP has trouble negotiating with a new router in which case that fixes it in some cases.
Dec 14, 2018Guru - Experienced User
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
ajkron
Dec 14, 2018Guide
Thanks for the reply. I'm at work but will get you all the info this evening.
